penna84
Maybe that's exactly what you should calculate..
Marco:smile:
p.s. usual my elucubrations;
but why choose thesis on topics of which you know little or nothing?
and I see that it is established practice.
From now on I'll give you all the secrets...to doing an internship in a company that sells components of regenerated cars, among the things they do had a problem on the hydro, I unfortunately knew little both the company and the topic and I accepted, there is the crisis no company needed a trainee and I wanted to start as soon as possible, only later I realized ke were in possession of very few data and that I should solve the problem almost totally from only.Better ask who's tires.
the data depends on a large number of variables, type of tyre and tread, inflating pressure and type of asphalt.
you have to find the worst condition for your application.
the area (print) of the tire (worst condition) is the area that creates friction, you have to calculate its size.
You must know how the tire moves when you dirt, depends on the architecture of the suspension and the offset of the circle.
the same tire can "screw" by twisting "on the spot", or by turning on its axis.
You have to consider the wheel blocked by brakes, worse condition, the tire can't rotate and must download all friction to the ground.
after having had an idea of these loads, on which you can measure standard efforts, you have to give a dimension to accidental efforts, typical of the "coupler".
This dimensioning should already be done by calculating the wheel hub, the reasoning is as follows:
If I hit at a certain speed an obstacle (beams the high ropes) what do I want to happen?
at what lateral speed (acceleration) do I agree that you damage the suspension?
In the end, what do I want you to break first (the circle, normally it is better to sacrifice yourself by deforming to save the rest)?
These questions should have already been answered up, the answer to these questions with the right safety factor (safety organ) will give you the size of the maximum effort to which the steering wheel will have to resist (maybe deforming, but never break).
This for a homologated vehicle, a sports vehicle or a quarry is different.
p.s.: unfortunately senna paid the account.
the problem is to create a test bench to test all the hydros and to understand if they work correctly, sometimes there are guarantees where the mechanic finds a difficulty in turning the steering wheel to the right or left, or it happens that the steering wheel is too soft.
in the company once a hydro is regenerated the only test they do is try it with pressure oil at the end of the race, so check if the seals lose and if the distribution drawer opens and passes the oil in pressure.
the calculation of the resistance to the wheels I needed to figure out how the distribution drawer behaved. .
I have always thought ke to machine stop the hydroguide to help the sterzata receive the max pressure but doing the accounts knowing ke the pump to 100bar and knowing the area of the piston comes me a force of 6000n thrust and seems exaggerated to win the resistance between wheels and asphalt and if the hydroguida always works at a much pressure below the 100bar xke do not put a less powerful pump! mha...
boys nn so + ke fish piglia!!:frown:
