Inguz
Good morning to all,
I have a little problem: if on my parts I carry out a joint processing to other parts, (see a quality mark that must be moulded on n objects) it is possible to perform a part that will be my processing and make it complementary with the part of the object under construction? In this way I should no longer remodel, in case of change of processing, all objects but only intervene on one part.
Could I explain?
Could I explain?
