urgent help!
  • Thread starter Thread starter Mero
Mero
at a first glance I did not find any discussion about it, I have a problem regarding solidworks 2008. I demand to develop a part of a tube to have the design to bring it cut on the sheet, how do I do?
Please help me.
In fact:
-The title is not generic at all:frown:
-"hello" is more than enough as a short presentation:frown:
- if you write "lamiera" in the search does not give you any results:frown:
....caxxxo without wanting I gave you a suggestion
I read the various discussions and in no way explains to me "step by step" how to do.. no commands are written.. I tried sheet metal in the menu "insert" but I think it's the right one. .
from solidworks awards f1 and give one last to the chapter "lamiera". There's everything.
discussions with the step-by-step commands will be difficult, fortunately, that you find them.
I found them and tried with the commands "folding" and "distendi" but nn works, at this point I think these commands do not fit my piece. .
I'm sorry again, but I have to present thesis and I'm panicked.
Then it will be good for you to relax and take advantage of the time that remains at your best. So far you've just lost it.
If you want concrete help it will be good that you let us know clearly what type of pipe you have to develop and provide the info we need to understand what to recommend then or places of pictures or attach the swx file.
caxxo, you have to make a script that automatically reminds new members that we don't have the crystal bowl! :mad:
Well, I'm gonna let it go, and I'm practical about the forums and I'm wrong. I don't think I should react like that. I'll spend more time left. thanks for the kindness
random shot:
the tube you want to develop must be cut axially at a point if it is no development
is a section of a tube with diameter 110 mm. I try to attach an image
Please help me.
..anywhere;
Do you mean a pipe made from sheet metal?
If so you do the sketch of an "open" circle (just leave a "fessure" on the circumference) and extrude it with the sheet command linguetta flangia on base. All there.
now you have your pipe cut along a generator, you can flatten it (always from the sheet commands) and/or put it on the table as flat repetition to obtain in 2d the design of the "developed needle".
p.s. read the regulation (in the home page in the upper left index) and the program help.
and do the easy step-by-step tutorials below ? of the program.. It's all explained.
First of all I tell you to attach the images you need to use the "manage attachments" tool in the advanced mode (as per regulation).
then this model is not a tube section since it has a fold that you can get only for funnel or molding. solidworks handles net peels or rolling.
to open this sheet you need applications like logopress.
Sorry, what do you mean by pipe?
from that "section" I find it very difficult to imagine.
please, if you want help explain better and post images (better directly the files at the point) meaningful; someone here is usually saying that we are not equipped with "glass bottle" (hello mf:biggrin:). . Try to put yourself in the shoes of those who have absolutely no idea what you think and see for the first time that image called "section of a tube", what would you do? ?
Marco:smile:
