sketch on drawing
  • Thread starter Thread starter simpson
simpson
Hello to all the latest inventor 2008.
I have to put on the table a file of together where besides the solids there is also a sketch, but the sketch together with the axieme does not show it to me, if I put on the table the only sketch makes me see it.... I hope I've explained
There's a way to do it.
try to go into the browser in the view you placed, select the axieme - button dx - get sketch pattern
but do you want to put an ipt into the table containing only one sketch, or do you want to put on the table the sketch of a solid part or what else?
this is the solution and also works in the assemblies.
both in the table of the assembly and in that of the part you can see however only the sketch lying on the plane of the view itself, you do not see the sketches made on plans perpendicular to that of the sight.( tried on rel. 2009 )
right, also because you would see only a projected line, being the two-dimensional sketch. . .
I'll show you an image so I can explain better.
I want to show in the table what you see in the image
go to the browser button dx mouse on the axieme that contains the sketch and select "need sketches model"
Unfortunately this worked and was convenient until 2009.
Unfortunately in 2010 there is the voice in the menu but it no longer works.
apart from jokes:biggrin:
in the table you can see the sketch. of course in the parallel view of the sketch plane and not in the others. therefore it is possible to front and back to the sketch plane and not in the lareal or isometric view
tried people
