flexibility control mirror
  • Thread starter Thread starter Pocoyo
Pocoyo
Does anyone know if there is the possibility, once generated the command "specchia", inside the window "definition of mirroring" add or remove the features to mirror? in my case it doesn't let me change the feature list.
Thank you, eek:
In fact it is not possible, that I know. the mirror command is good to use it to mirror a feature at a time. If there is the need to mirror a set of things, it is appropriate to create this set of things in a body and then mirror the body. It is obvious that if this set consists of two or three things you might want to repeat the mirror command two/three times, each immediately after the single feature. in any case you will have the opportunity to change your choices.
Thank you, eek:
is possible premium of the command make a multi-selection and then choose individually every feature you want. at this point you click the command. I allow myself to rectify that you do not need to mirror a body but you can also mirror a list of features.
Unfortunately once you create the command you cannot change that list.
it is however possible to explode the command and then have a set of features created automatically. so at this point we have the opportunity to modify or delete the features created by the program.
It is clear that at this point we will no longer have symmetries if we have modified or deleted features.
Hello, Jari, thank you for the answer. I didn't give this option.
I learned something:-)
Thank you, eek:
If your mirror comes from a series of cascading features through the reorder command, just place the features after the mirror feature.
or if the feature is unique through the replace command exchange the profile that defines the solid.
However in my opinion it is always preferable to associate the mirror action to a body (modelling with buleana) for cook at any timeposso to replace the single or group of futures that defines the transformation (wheel or mirror or symmetry)
This is really interesting!
Thank you!
I agree with littleyo, as long as you do not attempt to do this on a mirror of the solid current, in which case the message "exclusion runtime, press ok to end" and closes everything without saving :eek:
