I'm sorry, but I don't understand the spacecraft question to record? ?more correct to use or not of spacers to record oblique bearings.
I allowed myself to move here the discussion that is not expressly linked to solidworks but concerns more generally design and construction.in our office we have a debate whether it is more correct to use or not of spacers to record oblique bearings.
What do you think?
right, but even more flashing is the sampling...two separate elements, approached, with the same sampling makes the skin cling...trees or pins in the assemblies do not dissect.
how do spacers "preload" bearings? the precarious gives it to the wreath, at the limit the "limit" (if of the right measure).Is it correct to use spacers to "preload" oblique bearings during assembly of the machine?
I attach a bz
You can see it like that.how do spacers "preload" bearings? the precarious gives it to the wreath, at the limit the "limit" (if of the right measure).
mah! I have the impression that km6 is really useless, if you want to use the ring of space because you do not send it in line to the fixed part?Thank you all for the answers you gave me, useful or not.
Premitting that the difference between a design design ed una bozza(that post was a bz to give the idea of our discussion)
I admit that some elements were missing to ask for your opinion.
I repeat the question.
I attach a bz
Forgive me,Thank you all for the answers you gave me, useful or not.
I attach a bz
Yes, if they are calibrated.Is it correct to use spacers to "preload" oblique bearings during assembly of the machine?
I attach a bz
So, yeah.Yes, if they are calibrated.
the same philosophy of conical rollers, the spacer must limit the preload.
if you use spacers you can lock the wreath without any special shortcomings, but the spacer must be calibrated well and coast.
no spacers need a lock with controlled load, possible, but unstable, in the sense that it must be constantly verified.
At the end, we use calibrated shavings in front of the spacer, so spend less on making the spacer "rock" and then put a set of calibrated shavings with different thicknesses to exchange.
That's just a joke.So, yeah.
but it would only go for the ø25 to the right.
to the left the spacer against the ø40 bearing does not serve at all if not to change the axial position of the bascula/shaft group regarding the central fixed part; It doesn't preload anything.
Marco:smile:
Thank you allThat's just a joke.
