pika
It is the first time I cite myself in the realization of a wheelbase using the surfaces.
I did the sketch on the three orthogonal planes and then made a loft between two of them using the third sketch as a guide curve... It's obviously not the right way because then I can't control the loft in the most critical part.
the result is that the wheel penetrates the surface. On the contrary, I would like the wheel to be at least 20mm away from the tyre.
Who can give me some advice?
I attach the particular file.
