Fulvio Romano
Hello, everyone.
I have a problem. I have to get some effect on a steel piece, this degree of reflectance/diffusivity was obtained on similar pieces by sandblasting. I would like to capitalize this knowledge so as to obtain the same result even in the case of change of the supplier.
the problem is that by changing the material for sandblasting, at equal surface roughness, the result changes a lot. how many parameters do I have to take into account not to lose the result, but avoiding putting too many stakes to the supplier?
Moreover, how do you indicate a sandblasting? the term used on some drawings of "microblasting" what does it mean? gives constraints on grain, material, roughness, etc.?
