libraries and/or plugins and/or macros to share
  • Thread starter Thread starter Marcogeo
Marcogeo
do you have knowledge of sites where you can share how much in object? :wink:
If they weren't there, how about trying to get one? :biggrin:
Here is the usual posthumous question of the problem.... I looked at the sites. very interesting .. have I seen that much material refers to old versions of vw ... are still compatible with 2009 or 2010?
Some things do, others do not. in principle almost everything can pass from one version to another.
Okay, so just try.
domandina ot - is there any advanced function that allows the calculation of the volume of a building? or should you opt for the breakdown in simple figures?
I suggest you use the space object (I have no idea what it is called in the ita version, maybe room). It's a kind of polygon but with advanced functions, as parametric, directly connected to the internal database. was born especially to have under control surfaces and volumes.
Hello
space was not included in the Italian version, waiting for a more "robust" version.
thanks to the clarification!
even if I have aside the manual of the version ita, in fact, as betatester, I know little.
But it is a shame because it is a really useful tool. I hope it will be inserted soon.
I do.
Miiiiiiiiiiiiiii che caos tra tutte queste versioni! ma was own necessario?
I'm sorry. but consider that the ita version is much richer than tools suitable for our building, as it is right!
Today, for example, I am beating myself with windows that in the international version behave bizarrely compared to our standards;-)
I do.
Okay. is good for the more "ad hoc" tools... because, however, many others present in the international version are not translated?
possible that in the Italian version there is no possibility to export/import in ifc format?
I do.
...:biggrin:. . .
Why, however, many others present in the international version are not translated?
the functions not present in the Italian version are absolutely not "short" and are those that has been considered not worth wasting time, since they would not be used in our market. against the functions present in the Italian version and not present in the English version are really many. :smile:
ifc format: its translation would require several weeks of work: of its exclusion so far no one complained. in the previous versions also this format was rather "immaterial". now that it is stabilizing, it will probably be considered also for the Italian version.
paolo.c - if the ifc functions you need, contact the videocom technical support.
Sorry but at the end, reply after reply, you lost the interesting question. how do you manage to calculate the volume with the ita version without the "space" tool? ? ! ?
