copy and incollection
jim78b
hi premetto I can use little me10 drafting
If I have a design where I want to copy parts like I do? I tried type autocad with copy paste but paste them off scale!!!!
I don't use drafting anymore, but I think the problem is because they were on different scales. However with me10 I have never used the autocad type method but the normal copy dia command.
How do you mean the copy command?? ?if I opened 2 drawings as I do from one to another?
you can't open the drawings like autocads and cups. Load a drawing and then load another drawing that will fit you as part and then cover you what you need.
thanks to have patience do you know how to do a different type of restraint?? ? I have only three in the bookstore! I want, like, wood or something else!can't you create? ? ?
the restraints of me10 are far from the types of autocad restraints.
in me 10 you will not be able to sea do restraints like ar-conc or gravel or anything.
osd uses the combination of line types to create restraints on closed areas.
for paste copy, open 2 osd copy, select objects, confirm (confirm)
pass to the other osd and paste. (always from the menu, I don't know if it works via keyboard)
