estrudi surface
  • Thread starter Thread starter Riccardo Montanari
Riccardo Montanari
...is there a command that can allow the extrusion of only one superifice? ? . . .
to understand us... like the sup.extrusion of inventor.. .
so that you can only extrude a surface not a solid.. .
the command area of estrusione there is also in swx, it is the first of the list; any open sketch entity/form is extruded creating a surface with that profile/section.
But you should explain yourself better.
and if you want to make a surface with a closed line for example?
Extrude the closed line with the relative command in the surface functions (from menu or toolbar) and have the resulting geometry. I don't understand what your doubts are.
Oops, it's true.
with the same command area of estrusione it also starts from "closed" sketches.
forgive the inaccuracy.
but richer Again, try it first.
Marco:smile:
