inventor no longer blocks the lines after quotation
  • Thread starter Thread starter sghezz
sghezz
Hello, everyone.
I think I have a little problem with inventor 2010 suites I use at work.
Since some time it happens that starting from the first base sketch, place the lines and made its quotation, inventor no longer fixes the lines no longer allowing the movement of them.
sometimes it happens that to fix two lines that are perfectly perpendicular, of having to put also the angular quota of the 90° otherwise inventor does not fix it completely.
Sometimes it also happens that setting up a rectangle as a sketch, clicking on the base line and inserting the value relative to the length of this, inventor only gives the measure to the line that has been selected and not even bringing both parallel lines to the base at the quota indicated by me.
I hope in your help that I am becoming mad with sketches that lose references because of these problems.
hi to all, sorry if I repeat this topic, the same problem occurred to me too (inventor 2010) but I cannot solve it by pressing "persistence bond". I tried just opened the file, after the line position and after the quota position. Nothing to do. It happens to me in both sheet and extrusion module.
I don't understand where the problem is, did it happen to you?
thank you very much for the attention
