"merlature" on curvilinear sheet + development
reggio
hi, I find myself having to create an upside-down "t" support that develops along a curved path almost to "8", so I would like to create the base of the "t" overturned with holes/greeks/wires/wires, and then create the other part with male profiles to be able to frame it as seen in the image and in the annex.
I created base path and slits, I arose when I tried to do the other part.... :( tangent, not tangent... I mean, he didn't go out well. then I increased the depth of the spacing from both sides and it seems that it goes well.
But now I can't understand how I should do to create the vertical part (I will do it in another file separated from the base) in developing sheet (for laser cutting lamierist)
How would you do that?
  • Greca.zip
    Greca.zip
..ok, perhaps to create the developable sheet must create it from the profile directly from the sheet and not with the sweep...
tomorrow I try:
This could be an idea.. to "develop" better perhaps, but seems to work (bottom is a normal strip of sheet):View attachment Greca 1.rarof course the two parts will be mounted together
This could be an idea.. to "develop" better perhaps, but seems to work (bottom is a normal strip of sheet):View attachment 14377of course the two parts will be mounted together
hi, I had done it with the guided repetition but I consider your best and more realistic method (I refer to the faces of the thickness of the slits in the curve), in any case I anticipate a little play between male and female.
in any case I anticipate some game between male and female.
In fact, the part to be set up was just that.
to make fast I made the sketches of those cuts "copying them" from the male with the intersection curve (taking him the reference); Of course they should be a little wider.. was just to show you the developability of the vertical strip.
if you use curved repetition the steps are not right in curved traits; speech that has already been seen in discussions about repeating chain links. .
Marco:smile:
