and incredible how there are people who dedicate a life to achieve seemingly little renumerative goals.First flight of the solar.
President, what do you say?View attachment 14438
Hybrid doing it is easier, in fact, "it's not worth it!"I've been thinking about something like this but "hybrid." . .
Would it be possible for you? ? ?
other question for experts
Given the recent advances in the field of the turbodisel, you think it is utopia to think of a medium/long-range tourism plane that instead of turbofan uses a nice turbodiesel quadrimotor with propeller? ? ?
I figured... But you know, we start with that and then we see how the batteries evolve.. .Hybrid doing it is easier, in fact, "it's not worth it!"
:biggrin:
absolutely truediesel has already been used several times in applications on general aviation aircraft, dreaming of a 20mw diesel is not forbidden!
the turbodiesel could be competitive on half-mw units, up to 4/6mw the turboprop has numbers, plus the turbofan kingdom.I figured... But you know, we start with that and then we see how the batteries evolve.. .
absolutely true
but I wondered whether a pair of v12biturbodiesel with propeller or a pair of turbofan rr Trent or gp7000 is preferable at consumption. .
Got it. .the turbodiesel could be competitive on half-mw units, up to 4/6mw the turboprop has numbers, plus the turbofan kingdom.
attention that a turbodiesel must be able to give 500 kw practically indefinitely, then a normal motor of automotive derivation (only light enough) should be heavily revised in the declaration of maximum power and in rotation regimes.
small disgression in style "over and under the waves":from wiki:the project promoters are bertrand piccard, andré borschberg, luigino torrigiani and brian jones.
bertrand piccard, in particular, is the son of jacques piccard, the first (and only) man to descend on the bottom of the pit of the Marians, undertaking accomplished aboard the batiscafo Triesteteor "when the extremes touch"
