problem with terrain
  • Thread starter Thread starter geomap
geomap
hello to all I have a problem with max---I managed to make a surface with the tarrain command, but now I have to project on an image, but nn me gives it...how can I do? help me step by step to solve the problem??? ? ? ? ?
or even better if you would tell me how to export this autocad surface I would be grateful... I tried to export directly with the export command in autocad... but nothing the file when I open it in cad turns out empty, maybe you have to convert the surface made with tarrain in mesh...bhooo help me you
I would kindly ask you not to write in case, thank you
to project you mean mapping?
if you, you must create a material in the editor and apply it to the surface;
then adjust the appearance so that the surface is correctly mapped
theoretically terrain surfaces do not need any conversion, you just have to pay attention to export options
excuse me x the capital
thanks for the advice I will try to set better when I take.....while x the mapping...(I meant that) it does not work I have already tried...the surface became me only of a ltro color, I also tried to change the scale but nothing.. .
