inserire note in ambiente sketch
  • Thread starter Thread starter Rael84
Rael84
use pro/e 4.0. Can you tell me if you can insert notes in sketch environment?
Let me better understand what your need is, what do you need a note in the sketch?
I actually need a proe sketch to analyze some chains of tolerance and not to shape a piece. the note I just need to make the sketch clearer when I go to insert the image on a report
then use notes 3d. you see both outside and inside the sketch environment.
or in the sketch you can use the command to write texts. It's a letter-shaped key.
