athlon
Hello everyone,
I have to make this crank and to simplify /irrobustire I wondered if it was possible to make it in a single piece.
the dimensions are about 6 cm the diameter of the two wheel (actually, toothed wheels) , 10 cm the length of the whole piece , 2 cm the diameter of the central pin.
My doubts concern:
can you work the central pin to make it circular or machine tools need more space? (there are 2 cm between the two arms)
can you work external dentate wheels or even here the tool to make the teeth (right) need more space?
Can the hardening of the teeth and the pin be done?
My doubts concern:
