installation 3ds max - problems with c-dilla
  • Thread starter Thread starter Eta Beta
Eta Beta
...I have recently installed the windows final7 and I'm slowly reinstalling all my good, old and dear software:tongue:, among which also the 3d studio max4 (in Italian fortunately!). ..biggrin:
Unfortunately the program launch file shows me errors, as below linkhttp://usa.autodesk.com/adsk/servlet/ps/item?siteid=123112&id=5582547&linkid=9241177http://usa.autodesk.com/adsk/servlet/ps/item?siteid=123112&id=5582542&linkid=9241177I followed both the procedures indicated and reinstalled the c-dilla, but unfortunately I couldn't solve the problem ...
Has anyone had the same inconvenience? How did you solve this? . ..spero is not a problem of windows 7 otherwise it touches me to return to the xp ...to having many complications with this version, even with autocad :frown:
help me!
It's hard to use a 10-year program as a max on a new operating system... I think it's not supported. . .
Moreover, even autocad et similara, older than a certain release do not turn on sight or seven.
So I think I see her very complicated. . .
However, having the ultimate, you can use the mode that allows you to use xp in a virtual machine. so it should work, although obviously the performance (especially graphic) will not be at the top allowed by your machine.
hello giga, first of all thank you for answering me:smile:
the fact is that, while having the latest versions of max, autocad and other software, in fact nothing has changed, in the sense that the last versions are only clones that do not have much more, indeed often sin in some good things that had the old relese. and cmq even the most updated have problems in windows7.
who knows well and always the max, knows for example that version 4, besides being in Italian (what comfortable, don't deny it!) has a tabbed interface, where there are all the commands without need to customize or move the ui, you have everything available!:finger:
....then we say the truth, the microsoft has taken a beautiful chant: create a more beautiful graphics version in the ultimate, which then does not actually turn the graphics and rendering software?? ? :confused:
I think it's good that we're the consumers, aren't we?
You didn't get a...
1. to have max in Italian when nowadays the computer graphics, from wherever you look, speaks English, is useless. online material, yourtrial, cg sites between mileages, etc... all in English; try translating the commands that indicate you in English on the Italian is crazy. then you want to put the technical terms spoken in Italian and spoken in English? It's cooler... (but this has nothing to do with it)
2. in all the software you mentioned, if you stayed with them so old as between max 4 and the current one, they did many, but many, but many improvements that you have no idea. If you tell me from a relase to the next one, I can also give you reason, they just improve, but as old rhymes so much, those "just at a time" has become so much. the axis constrain in max, I do not know how I did when there were, for example, more all improvements on ik, selections, etc... but happy you...
3. customization of ui is the most useful thing in the world
4. plug-ins? the max "force" are also its infinite plug-ins. I doubt you still find it developed for the 4th.
5. all graphics software turn on 7. then if you want to turn autocad 5 that ran on dos on win7, this is your problem, not microsoft.
hi the apology, but maybe you missed the step in which I said that
"cmq even the most updated have problems in windows7";
This means that I own it, besides I referred to max 4 regarding installation problems, I did not mention autocad at all, or others.
it was hypothesized that I also referred to autocad but actually, the
My request for help was for max....maybe I didn't express myself well or you didn't read well: I own all the versions of all the software you read in the profile...even the last!
It is obvious that I am open to all innovations, otherwise I would not have installed
windows 7; but I repeat, windows 7 is a colossal flop almost comparable to the millenium and view.:biggrin:
none of the software runs smoothly, neither the old versions nor the new ones, and I'm not the one to say, it's the microsoft in person!:mixed: in fact the window shows: the program presents a known problem of compatibility with this version of windows. for an update compatible with this version of windows, contact"...". :eek:
in another case, instead it does not launch the dll (max 2009 word).
I read a little around and filled the forums of these complaints, and precisely
I was wondering if someone had good news with some resolutions, but I think they're not there for now. I think I'll finally go back to the xp....
But take away a curiosity, indeed I throw you a provocation: tell me one thing, command or other, that you can do now with autocad 2010 and that you can't do with autocad 2004 (for example) or choose some other program you want to compare! Open me your heart!!!! :biggrin:
p.s. I had rushed to read in hope that someone had the solution and instead... .
tell me one thing, command or other, that you can do now with autocad 2010 and that you could not do with autocad 2004
Finally someone who has the courage to say it!!
I removed my partner the last license acad 2004 and I " updated it " to 2008, at times kills me ( and how I understand it )
I pay the subscription, but say I'm happy with the " improvements" that allows me the constant update would be a lie.
ps. : I don't have win 7 yet, let's figure out what's waiting for me:biggrin::biggrin:
boh, the mancanta desire to "inhabit" the new relays does not translate into little functionality. I myself con nventor did not want the ribbon, but then getting used to me I find it very functional.
autocad has long been that I haven't used it assiduously as I could have done it years ago before I switched to inventor, I don't know well that steps forward they did, but I don't mind the ribbon bar. the 2004 (and on this I give you reason) is however the best relase they have distributed, on this there is no doubt. I remember definitely from 2000 to 2004 the modification of texts with double click, and the dynamic formatting of texts... the 3d of the last relapses I know that it has changed and made more comfortable (ucs less "inked" and more usable to esmpio), but I do not want to talk too much about things I know realistically.
what version of win7 do you have to have problems with max2009? mine still runs on win7 ultimate x64 and compatibility issues I never had them with any software, because it initially had similar problems, but today also that problem does not have (on the other pc I saw ultimate x64).
Now in a forum of any kind, there are untenti "experts" and users who complain about everything, there are those who complained of sight without even having tried it and relying on the "voices of corridor", so I trust relatively of the judgment of others, I rely on my experience most of the times.
However, allow me a line in reference to max4 with win7, try to mount a latest generation blue-ray player with only hdmi attacks, on a 1940 black and white telvisor... that maybe he didn't even have the scart grip and could complain about the producer because you can't attack him. . .
Finally someone who has the courage to say it!! I removed my partner the last license acad 2004 and I " updated it " to 2008, at times kills me ( and how I understand it )
ps. : I don't have win 7 yet, let's figure out what's waiting for me.
Thanks for the :smile compli:...we are the ones that use it therefore the biggest ideas, for those who design these software, must be taken by those like us is the average user...
ilario!!!:biggrin: are very accustomed to new releases (so you call them?) and use them and are not a bad user, they are quite good :tongue:! !
However: the problems of installation there are and I repeat it is not me to say it but the same micorsoft, which alerts with the popup, and as regards to be careful to types of oxford filling the mouth of parolines in English type: layout, release, etc.etc. I care little: w l'italiano! so I use to say: version, program, layout. ..without doing too much groin!! !
...I liked being able to exchange opinions and see who catches the ball at the leap, and without too many words he really says what he thinks without being too wise, but spontaneously. ..this was the purpose....
I don't say you're wrong, we'd miss it! But everyone says his...in simplicity:smile: Hi.
