caddrite
  • Thread starter Thread starter Exatem
Exatem
Greetings to everyone.
I found the term "caddrite" as an indication of material. I've done an internet search, but it didn't make me very clear. Does anyone know this material? from what I saw from the artifact (I detached a piece) is a kind of closed-cell foam polyurethane (type solidified foam). If possible, the other characteristics.
Hello, exa. "Last bbene"?
as I read the title I thought of a form of arthritis caused by a ruthless use of cad :biggrin:
I'm sorry, but I can't help you. ever heard of this term (which is "commercial" use? It should be traced back to the correct technical name of the product).
However:
by browsing an old drawing found in archive.... from what I saw from the artifact (I detached a piece)
from the archive design did you manage to detach a real piece of the material? :confused: see, once there were designers with balls, other than 3d.:biggrin:
Marco:smile:
However:
Marco:smile:
Bye-bye
I guess I didn't explain myself clearly. the indication "caddrite" is on the drawing (old). the piece of material, I detached it from the real piece that came at its time realized. It is a kind of solidified foam like that used in the fiberglass sandwich of boats. As I have to remake this structure updated to the new needs, I wanted to identify the material to replace it with something current but with similar characteristics.
p.s. Will the arthritis caused by a disproportionate use of cad be considered a "professional disease"?
hi, I also tried to do a research but the result was zero :confused: If it's an important thing maybe the only solution is to send the sample to some companies that analyzes materials but it's a solution that has a cost.......
p.s. (for extreme) I gladly answered your private message.
Good day:finger:
