clear with color selection.. . .
  • Thread starter Thread starter Stemox
Stemox
I tried to delete with color selection but I failed in my intent.
This is what I did:
having in the drawing some lines of a color (in this case green) I tried to erase some (not all) with the selection command without going to look for one by one.
command: deleteselection>green>ok>confirm ...in this case it deletes all then.. .
command: delete>green>ok>window ... erases all I enclose in the window.
How do I delete only those enclosed in the window? ? ?
This is what I did:
try to reverse the green with window
command: deletefinestra>verde>ok>
many times with the selection box just reverse a xche sequence functions
spent more than a year, I hope you found the solution.
However it can be useful to those who are still looking for it.
excl.
> Select all colors minus green.
hi, resume this discussion:I'm using autocad lt 2015 and I can't find the appropriate command (if it exists) to delete entities (e.g. by color) by capturing them with a window (it deletes all the sheet)
thanks alessandro
