bonus pack revit 2011
  • Thread starter Thread starter arte.progetti
arte.progetti
Hello, everyone.
I have to expose a problem that I found on my "machine" one of the xps
I'm sure it is due to some compatibility problem between software and hardware, it's because after installing the 2011 revit bonus pack downloaded from the autodesk site, I found a serious problem with the program following the installation: that is the size of the project browser window occupies entirely the work area as well as for the property panel window. result: it is impossible to work I am forced to disable the view of the project browser from time to time to be able to see the work area.
problem!: it is impossible to access in some way to the right edge of the browser window so as to resize it, I acted disorderly on the title bar of the window in the vain hope to get some hopeless result, I got a partial result now the project browser is back to place but the property window is gone from the view of the work area, and use spider seen the expression "outside from the view" because it is entirely influent to activate the user interface This happens with autocad with some toolbar "anarchic", but at that point you reload the work area and everything back to place. question is there the possibility of revit working area as from first installation? precise that I have already tried both to repair the installation and to completely reinstall the program (after its complete removal of the program) I would like to avoid going to correct the registry so as not to have to reinstall everything again and request activation of the license. Thank you and excuse the lunghaggine.
The same thing happened to me, I wrote to autodesk, to my dealer... but still no answer. revit 2011 still gives many problems, it is unstable and then you have forgotten several things.
quoto, often stops at startup and uses ram abnormally.
Fortunately I am still using it transversely using it as main autocad software, for those who work mainly with revit perhaps it is better to wait a little longer:)
Is it possible that you can issue a problem/conflict with the video card?
revit, in the initial instructions, reports which are compatible and not compatible video cards.
and putroppo I was illusive too early: mad: problems are there, there are. It seems to me that the quality jump is only apparent. I don't know if some pious soul tried to insert personal textures, it's a mess not to end.
and I can't understand how in realistic mode you see everything if you launch the render becomes all black :confused: I carry the autodesk discussion link and it seems that having problems is not the only one.http://discussion.autodesk.com/forums/thread.jspa?threadid=772868&tstart=0Maybe someone solved the problem? if I amount my texture by running the render everything black...I wrote to the assistance but these have evasive answers like "reinstall the material files,,:frown:" or manco answer you and you are paying the service or not?? ! !
Hello, everyone.
I tried with a project of the ver. 2010 imported in 2011 and relaunched rendering, everything works correctly.
of course the material file is still that of 2010. the material file of 2010 must be added to the additional rendering path: options>rendering ".....\revit2010\data\rendering\assetlibrary_base.fbm\"
a gianfrank I have no words....:smile: but black misery because then excellent support lies do not have such immediate answers? ? ?
Go well six and stay big:4425:
thanks now funza todos and I hope that this will serve others because I have seen desperate people on this passage.
someone knows what "autodesk vault 2011" needs, I saw that you can download but I don't want to mess up my life before the time.
thanks for any answers;o)
thank you frank I read but if I don't understand badly you need to "conversale" with other users on a same project? If so I prefer to be lonely....; or(
No joke of course!
I take the opportunity: do not exist a simple and rapid way (autodesk programmers) to solve the ark problem as well as made for the pillars? I tried with the masses and then everything else as brilliantly indicated by you and others but always remains and cmq a problem.
No joke of course!
among other things in revit 2011 is already integrated the streument to work simultaneously and share a same project on multiple pcs.
By the way, have you ever used this function? is it easy to use? Does it work well?
No joke of course!
from what I managed to understand seems to me a sw prepared to create a "environment" of work, then a computer "predisposition" of folders in the computer/server/site (volgarmented by a non-computer...) accessible by users who work on the same project
in it can be deposited logs, documents, etc. in availability to users according to the various levels of access.
the structure of the working environment should be set according to the various steps (customized by the user) from the development of the product to the creation, type:
- conceptual idea
- first prototype
- development
- revision
- etc.
with search, control, modification, document printing, access management and access levels
...pses
... :biggrin: ...
If I have to say mine, I was waiting for 2011, in the meantime I downloaded the demo in English, with a wall decal of a sundial I nailed the render, after some moments of panic since with 2010 it did not give problems I had the idea that could be this to mess up, I removed it and the render left.
However last year I asked why putting the white color as a background in place of the clouds the metal parts were rendered black, I am still here waiting for an answer.
In the meantime in recent days I paid € 700+ VAT for the sub, I comumque to these I repeat it every time I meet them that seem too many for what they give us
I agree to make too many 800+iva and if there were no forums and some good soul responding would be even worse. I don't want to take the accidents from someone but cad3d seems to me the best organized forum, but peeing here and doing it always good!
about continuous facades I saw how allplan2009 solves them in an egregious way, including those inclined and with "rackets". I downloaded the files from c.g.c.tec but it seems a little messed up the story though I have to say that the technician of the company was extremely kind and patient.:36_1_12:
but does not exist a simple + way to draw them?
at the last revit presentation meeting 2011 I met a geom of Milan that had used I think those files for the facade continues with spidernetti and seemed satisfied.
As for the sub of revit, I did this year only because with this version I see all the processors on the machine and other useful things that however I think are not worth the 7/800 euros of sub.
next year if there is not something revolutionary like the use of gpus of nvidia
for the renders (in the last mental ray seems to have implemented it) I do not shake a penny
after all ground zero to n.y. They designed it with a revit a few years ago.
and make holy words shared :frown:
for spiders that was a geometra of milan:biggrin: and I am an architect of bergamo :frown: sometimes what it means to be born in the city gives you that extra point!
I'm joking, and as my poli prof always said... we're in the hands of the janitors... and we dott.arch. then :confused:
to me at the pole in the years 75-80 he enrolled me at the exams a bidello and I didn't even have to queue, a panettone at Christmas and the dove at Easter and away
p.s.
say there are about 10000 revit licenses in Italy
make 7/8 million euros of sub, we make 5 and only in Italy
there is to pay an army of programmers to improve the program
And what do they do? They're putting you in a little bit
things that other programs have already had for centuries and that among other things cost much less
