arte.progetti
Hello, everyone.
I have to expose a problem that I found on my "machine" one of the xps
I'm sure it is due to some compatibility problem between software and hardware, it's because after installing the 2011 revit bonus pack downloaded from the autodesk site, I found a serious problem with the program following the installation: that is the size of the project browser window occupies entirely the work area as well as for the property panel window. result: it is impossible to work I am forced to disable the view of the project browser from time to time to be able to see the work area.
problem!: it is impossible to access in some way to the right edge of the browser window so as to resize it, I acted disorderly on the title bar of the window in the vain hope to get some hopeless result, I got a partial result now the project browser is back to place but the property window is gone from the view of the work area, and use spider seen the expression "outside from the view" because it is entirely influent to activate the user interface This happens with autocad with some toolbar "anarchic", but at that point you reload the work area and everything back to place. question is there the possibility of revit working area as from first installation? precise that I have already tried both to repair the installation and to completely reinstall the program (after its complete removal of the program) I would like to avoid going to correct the registry so as not to have to reinstall everything again and request activation of the license. Thank you and excuse the lunghaggine.
