update albero
  • Thread starter Thread starter Dariolix
Dariolix
Hi, everybody, I wanted to ask for something on nx5.
I happen many times that changing a piece, some features that have nothing to do with the change go wrong and so I am forced to put them back.
I wanted to know if it's possible to remove the automatic update that he does every time on the features, to understand the previous ones where I go to change?
If I were you, I'd try to figure out why those "nothing has anything to do with it" crashes during the update.
will crash because some revolves or some holes in short, however some Boolean operations for example go to be made on points where they should not... They were good before the update and bad after... tomorrow I will call assistance just to understand how to avoid these crashes.. .
cmq a solution is this to open the model.. go into the tree of the elements and make future make currents for each part of the model... for example first for the linked body (for example) and then update it for the sketch and update it (by changing only one of the variables and succeeding from the sketch automatically updates anke the rest of the variables that have changed) then for the various extrude revolves etc etc.
I hope I'm not too lost in the example
