distinct attributes on the top 9.0
  • Thread starter Thread starter Plaguebreath
Plaguebreath
Hello everyone, I am here once again to ask for advice on a rather annoying problem that showed up with the latest version of 9.0
In practice on the drawing you cannot see the number of the detail that is automatically created using the renumber key and the amount of the pieces.
I also wanted to know if there is the possibility of creating automatic reading macros of fields related to a particular particular name and standard number.
See? something because this forum doesn't work!! !
you are a toptron user who might use 75% of the entire package
if users of the forum largely use only the cam or 3d at most you will have no answer about it!
I've learned almost everything, but I've got some gaps that I can't solve, so I've got a passionate advice or we can agree on how to use a program mix or go to assistance.
Bah... .
Thanks monster of moral support but are still with the peas in the bag, and so???? the assistance has already passed and their answer has been the following "we know nothing about the attributes, we will ask the headquarters, however good for the 10" now if this is the assistance I hope to receive more answers from a forum like this:)
... the answers you received are why, after a while, I stopped communicating with them.
I no longer reported bugs, asked info etc. always approximate answers.
They know the relative answers you have more common problems. when you experience the deaf or the problem drown in the desire to work, sweat, study solutions. and the answers send back to your patience and need to solve the blinds.
I personally beseech myself in what I do, totally arrogant, presumptuous and antipathic but I have solved the problems that none of the suscritti would have ever done.
I'm sorry if, as I said, I was appetizing. ;-)
Good job.
dylan.
for monster. (a)))))))))))
I am convinced of this also because when you take the issue magically they always tell you that they solved it but in the release +1 that they just proposed you .... However, apart from this, is it possible that only I have this kind of problem and no one has already faced it?
..possible. Why not?
In the background is a very flexible and powerful system. being composed of several sections with different functionalities, it is logical that the needs of us all will always find some "defect". This is normal and it's so for all the software.
I always say it, and to me first. The grass of the neighbor is not always green.
in the specific case I'm sorry but I can't help you. I hardly know how to use the symbolic text in the table masses:-/
dylan
Hello plaguebreath.
they are right both dylan and monster: you have to bang to solve the problems by yourself since technicians (often) know less than the user.
I see if I can help you; I have changed software for a long time and stayed at 8.5 and I hope that what I will say is not changed in the meantime (which often happens when updating versions).
Meanwhile you have 2 separate commands: the first is what "generates" type table the list of parts the second is what inserts the "pallining".
It seems to me that you have understood that the table you have managed to change it according to your needs (columns, rows, etc.) keep in mind that many indications that will appear in the table are those that you can give in the properties (advanced) of the single part.
with regard to the pallination there is a command (automatism...automatic juncture) that, after selecting the view, inserts in a disorderly but consistent way with the table you created the famous "pallini"; these can be deleted or moved to your liking.
I hope I've solved your problem.
greetings and good work
:biggrin::biggrin: the grappa??? and beer with 5l...
cmq is moved is right in practice once the mold project is done in the end you can create the distinct that then you can update both in the assembly environment and the 2d environment in the same way...no more! :wink:. you can add voices and remove them!! !
So what happens toptron puts in case numbers in the sense that it starts from a chronology to give the numbers but they are completely editable throughout all the only thing that does not change is the quantity of the materials in assembly!! ! !
then I always say why we don't all connect together with skype and we make a nice chat about how to do and how not to do things would be fun and educational because surely every one of us knows a little more than due.... good connoisseur a few words (right
ahhhh I forgot who manages to have the Moldovaex3d for filling cavity contact me that I want to see what it does!!!! !
:eek: it was now
Hello marines
... did you mark it in red as a grammatical error?? then you tell me I'm always full of prosecco like zaia:biggrin:
