there is no more "save with name .dwg for autocad"
  • Thread starter Thread starter ranino
ranino
Hello everyone
i inventor 2010 e autocad 2009
I want to export a .idw in .dwg for autocad.
from save by name or save copy with name I no longer appear in .dwg for autocad, but I find only .idw and .dwg for inventor.
Is there any options somewhere?
I have not understood why you have autocad 2009 when with inventor 2010 is also included autocad 2010, however. . .
to me when I do "save copy with name" appears in the drop down menu the option "autocad signs", just choose that and then choose your preferences in "options...".
ps: It is a good rule to present yourself in the discussion when writing for the first time
try to check in environments/management if you have loaded the dwg conversion program. I'm not sure it's a solution, it's just an idea. Bye.
I apologize for not showing up, but where do I find the thread for the presentations?
I installed autocad 2010: nothing.
I uninstalled and reinstalled inventor 2010: nothing.
I don't understand what happened. until 15gg everything worked "to the great" (as a well-known night presenter says....:finger: )
with autocad 2010 I can open the designs saved by inventor in .dwg format, but only opens them in paper space. Is there a way to import them into model space to edit them?
1st question:
in the first thread listed in the inventor forum.
2nd question:
If you don't need the inventor's dwg, you can save "as a dwg of autocad," so you can save them immediately in model space. . .
I only realized now that it doesn't even let me open .iges .step etc.
It doesn't even let me save them, it's like there's no more "the conversion module" or something.
in additional tools/modules/ select the translators you need
the fact is that they do not appear within the list of additional modules to be uploaded to startup. I find only that for pdf, jt, dwf, but there is no iges, step etc.
I also tried another inventor 2010 but nothing. I have to put a reducer in step into a set but it's becoming an epic enterprise.
I don't know what to do anymore.
I also installed autocad 2010, then I uninstalled autocad 2009, then I removed everything. then I tried another version of inventor in English. I also tried to remove folders in local document&settings/sets etc etc.
but I can't open and save files in step, iges, sat. nothing. I'm hurt.
try installing the translator add-ins for inventor 2008 on this page:http://labs.autodesk.com/utilities/inventor_shrinkwrap/or try installing the service packs that usually contain the latest translators released.
cmq is all very strange, reinstalling 2010 you should find everything. try to uninstall everything and do a thorough cleaning of the pc by eliminating all autodesk folders and doing a thorough cleaning of the registry keys (I use ccleaner). remember that they are all powerfully harmful operations for the operating system then usal as last beach.
look at this autodesk:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=2887771&linkid=9240617Good luck
