lustro
hello to all, I spuled around with the search command, but nn I found answer to my quaint: in the environment together (and maybe part) there is a command that allows to rotate the assemblies (part) of certain predefined degrees? ?
I know that you can set sw in such a way that at every pressure of the arrows of movement correspond certain degrees of rotation, but nn there is something more practical :smile: ? for example, if I realize a set (or part) and then in the table I realize that I need a certain visual angle, I would like to create it and then save it in the bar of the tools of orintment (the one that appears clikkating on the bar
in the table environment if I use the rotation command, a shutter opens in which asks how many degrees turn the view: Well, I'd like to know if you have something similar in the environment together and part.
Thank you all!
Thank you all!
