maca75
I would argue like this:
1 electric motor catalog or producer sites maybe find some applications to choose engines.
2 to think that an electric motor will certainly turn at a much higher speed (sometimes that required) then a system to reduce the turns you have to find it (to pair pulleys, gearboxes, inverters)
3 know that the power is p=m*w (pair * angular speed) and then see your engine size you need, of course you have to consider all the factors you eat power (service factors, frictions, returns) things you find on the catalogs.
4 for the gearbox itself, see producer sites and also find technical guides of choice
5 to think that the process of choice is iterative, that is, make a choice and verify and then add if things are not going. Maybe as first you see if you have gearboxes or engines available as a first attempt.
don't get discouraged if you look on google opens a world
