Land start and end points
  • Thread starter Thread starter blubossa
blubossa
selecting a geometric figure that could be composed of:
open polyline, lines, arches, oopure uuna closed polylinea,
I would like to set up a circle at the beginning and end points of each entity.
and that he would bring me back to the window of the entities found.
do you have any suggestions about this? Thank you.
bb
bb
Try to see if this suits you:
tools>stretch attributes,
and at the end of the procedure carry xls files
Excuse me, but what does the attributes have to do with the beginning and end point of a polyline? Arch? Line?
bb
a little help to what you want to do.
the file lisp contains a command, brandsf, functions, fnp10_p11 is the main, the others are service to this.
the brandsf command wants to be only by example.
load the lisp and start brandsf, select a line or polylinea or lwpolilinea or arc and this will mark the beginning and end of the entity with points.
bye
I also included this, I forgot:
; function requiring to select the entity. uses entsel function.
(defun sing (prompt / a)
(while (not (setq a (entsel prompt)))
(setq a)
bye
Hello rpor66,
I tried to use the lisp but I go wrong, look for another function.
Here's the mistake:
No function definition: rpptHave you forgotten another function to attach?? Would you send it to me?
Thanks for everything
bb
thanks works perfectly. ...... ,
I am expanding the routine that filters open polylines and closes them... .
I can't reassign to the code dxf 70.0 code 70.1 to close the polylines.
while if I use (command "_pedit" ename_oggeto "_close" "")
Nothing works.. .
suggestions?
bb
charge the lisp if not sing does not work.
(command "_pedit" (car) (sing "sel poli: "close"
typing the full command name, if autocad is in Italian, it only works con The underscore, however, should eliminate the last two quotes as they are not needed.
rather, we are sure the name of the poly is just ename_andgeto?
Blue, have you forgotten? http://www.cad3d.it/forum1/showthread.php?t=9096&page=2 :rolleyes:
You're right, unfortunately I had problems with hd and I lost a lot of info, I remembered I had already treated it but I couldn't put it together.
Thanks again... .
bb
(defun c:cply ()
(command "_pedit" (car) (sing "sel poli: ") "_close" "
(defun c:sing (prompt/a)
(setq a)
back to video the popup menu of polylinea options, even if imposed filedia at 0.
There's something missing.......... .
I press that reassigning code 70 to 1 the problem I solved it, but it is just want to understand and control better other solutions.
another question
with pdmode I choose the type of point I want to use within the design,
but how can I define the size of the point? Is there a way?
bb
remove the c: in front of sing...
(setq a)
....or add it here:
(defun c:cply ()
(command "_pedit" (car)c:sing "sel poli: ") "_close" "
(setvar "pdsize" .... .
(setq a)
....or add it here:
(defun c:cply ()
(command "_pedit" (car)c:sing "sel poly: ") "_close" "")
It's working.... thank you.
but by generation type of line what is it meant?
corresponds to the plinegen variable
"sets the mode of generation of line type models around the tops of a 2d polylinea"
Sorry, I was wrong.
I wanted to ask what situation is convenient to set plinegen 0 / 1? ?
bb
Hello, everyone, excuse me if I open the discussion. the command works perfectly but is it possible to apply it to all the polylines present in the design?
