disable odd palette. . .
  • Thread starter Thread starter POONCH78
POONCH78
they installed in the office on 2010 (from the previous 2007 sp.5), I noticed that by selecting any quota in the masses on the table the 'tavolozza quota' appears. it will also be comfortable but to me sincerely breaks some boxes, only that I can not find the option to disable it, not even in the online guide.
Is there a real way? ?
no, but from sp 3.0 they modified
size.
now appears as a button that expands on demand
Then I should ask to install the sp.3, otherwise I will have to live with the palette.. .
Yes, do the momentum and
You'll see how they improved it.
Lombardy, where?
I'll go up. work
in Switzerland.
I bergamo province.. and I am lucky to work at 3-4 minutes from home..(depending on traffic:biggrin:)
I resume this discussion because it was exactly what I wanted to ask.
Are you sure you can't disable this odds palette in any way? I have installed sp. 3.0 but in any way they present it, this option I find useless, embossed and slow.
I hope we have predicted that not everyone goes to genius these forced innovations
hi, actually with sp.3 the situation improves a lot, however I do not think you can still turn off. . I tried to search the guide but nothing, then I didn't want to waste too much time. Let's say I'll do it right. .
I also found other 'bests' that in my case, are worsening, for example when you replace a component in a set, before you presented the 'wife' button and also the window in which to type directly the path of the file to be taken (which if as in my case you always find it often and willingly in the same folder as the one to be replaced, you just had to change the name of the file at the end of the path and type in it) while now:
- there's just the puff, so every time I have to do everything by mouse, and a little bit I get kicked, more than anything else the fact that I can't choose anymore
- every time I've got to look at the preview of the couplings, even if I don't give a crap, and even here you can't turn off. . .
I stop if I don't go off topic
Yeah, you're in the vein of update. with
the sp4 solves... the instrument
Now it's less invasive.
Hi, mike. He couldn't see you anymore.
I also with sp 4.0, the palette opens only if you pass over to the iconcine that appears.
(or.t.)and with multibody sheets have you solved? I haven't tried.
Marco:smile:
Actually, I already have sp.4. it is that this option does not do exactly to my case, because as soon as you select a quota you appear this icon and to remove it (and then do what you have to do) you have to press "exc" several times.
these options that would like to be innovative, to whom as I have long programmed in the keyboard commands everything he needs, break only the boxes! . if there is an obligation to release a new release every year you have to justify it with new ornaments, although in reality nobody feels the need!
Marco:smile:
hi marco, I answered from the beach... in Sardinian...:biggrin: today
I am in gattabuia...:mad:. .
For lam-multi, a colleague of mine is testing
on a 64bit machine with seven and something improves.. .
however they are not yet reliable, even in beta2011
there was no correction to this huge bug. I'm confused.
to resent us. . .
I resume work at full speed from 23 August.. Good holidays to all. :smile:
hi marco, I answered from the beach... in Sardinian... today
instead they are in gattabuia
to resent us. . .
Good holidays. .
..drawn.. mannaggia attè, mannaggia.:biggrin::tongue:
I use it moderately and I feel very useful.
only thing I noticed that if you do little more than 4 or 5 parts start to become really heavy to handle (not as size of the file, but just as type of processing evidently). if they become part of a whole, not even too big, the times of reconstruction and rescue are eternal: eek:
- Good night. .
greetings soon
Marco:smile:
so convenient the panel that appears near the quotas in the table. is very comfortable for repeating tolerances and customization of quotas. and if I don't know you want to see it just moves the mouse quickly and the window disappears (sw2010 sp2.1).
I think it's always a matter of getting used to. banal example in itself but seems a tragedy in the company where I work: my boss has customised the icons in 2004 and since then he always wants them and only so... He misses half of the stuff even indispensable but does nothing. if you find yourself working as on swx as well as you install it says you find nothing. sin that not finding anything is the opposite. he lacks icons. I have always left it as it turns out by default not to preclude me any road or command. My customizations are related to graphical streamline, 3 fast keys and background color.
In the end, the sw2010 menu is like office2010 as a spaceclaim as an inventor 2011... so get used to it for a while before having the syndrome "I can't find anything".
to turn off the bar go to tools / customize and turned on or off display in selection
Yes, but you lose the various quick options, for example project view... and more.
I leave enabled, if you take the "mouse" you will find yourself well.
