solid no longer usable? catch v5
  • Thread starter Thread starter gfix68
gfix68
hello to all I am not a caia v5 expert until now I have always worked with v4 but now needed work lead me to have to use also this product.
the question is the following I have a solid that is represented, in the tree, with a small parallelepiped and a small red lightning down! Can I still use this solid somehow? that is to reactivate the whole history of the solid itself (the tree)?
Thank you all!
Hi. .
that I know, you cannot reactivate the story of a solid that is shot down. the symbol indicates that the solid is a history-free entity because it may be imported from catia v4 through the migration process "as result", or it comes from a step conversion, or it has simply been copied and glued "as result" by another catpart or within the same catpart. in any case it is still possible to operate on that solid, perhaps adding parts, cutting it, adding holes, replenishing faces, symmetry it etc...
tvi71
Thank you all!
depends on the type of license you have and the geometric complexity of the volume.
if you have the menu in your cat, this allows you to reconstruct the features that make up your volume.
great!!!! It works thanks really... I still have a lot of road to do with stands "v5" good night!
