pkg file opening
  • Thread starter Thread starter MFT
MFT
Good evening.
I have a pkg file that the program can't open tells me insufficient memory or I can't open the package. It shows me the icon that would seem right there is a way to open it... if it exists. is a file I had deleted and recovered from the disk.
Good evening.
I'll answer you quickly, I'm hanged.
a pkg file is a compressed set along with an environment file.
If one of the parts of the axieme is corrupt, you don't charge the whole axieme.
in the osd directory you should have the binnt
search inside "uncompress" and "cpio"
are two unix derivative commands
If the axieme is big (single parts) put the pkg in a dir of work.
the command should be:
uncompress < your_file.pkg > file_temp.cpiopoi:
cpio -i < file_temp.cpioin the end you will have a file (0 1 etc.) for each part of the axieme.
must be loaded by osd command line as:
"load *.sd"scusa ma vado a memoria su unix was a and dovrebbe andare anche su pc.
speriamo bene, ciao
then created me the .cpio file but the sucessive phase to transform it tells me unexpected eof
and stops there the cpio file has zero size
Did you try to disappear with 7-zip? for example solid edge files are compressed files that contain various other files, and 7-zip manages to extract the content.
But when you load the pkg in osd and it gives you the error, the tree of the parts empties?
I don't charge anything out of my loading error, the pkg file has size so I assume there is something inside while then the cpio becomes zero size
I tried to make a uncompress of a pkg file that load normally and also he creates a cpio of zero size. What is the uncompress that is not right?
Is the syntax correct?
check on the help.
eye to symbols < > which must be separated from spaces.
can you zip and post the pkg? or is it too big?
I did what you told me. what seems strange to me that performing only the uncompress command I remember that on ux told you how to use the syntax does not tell me anything, while with cpio it tells me usage: -i -o.
the correct syntax, the file is very large so I can't post it.
cpio is no longer used in the latest modeling versions to create the package. if you open the file with 7zip you will find a 0 file that you will still not be able to load if the pkg is damaged.
I have seen that on the pers of my osd is present the command "recover pkg"
(who frankly never used)
Try to see your...
taking back what he says andy
to decompress a .pkg file just rename it in .zip and then decompress it.
one or two files will be created according to the content.
later drag & drop into the modeling window.
Hello!
