self-powered pneumatic system
  • Thread starter Thread starter adiaz74
adiaz74
hi to all I have to build a forklift with pneumatic system auto powered, I mean a plant with tank daria and
I wanted to know if anyone can feel if you can do it and if you can give me some gezie advice in advance
I think it doesn't even comply with the safety rules.
maybe with an air/oil multiplier.. .
not a forklift as you can think I explain better
the weight that must lift varies from 10 25 kg for a height of 30cm.
we have masks where we load beams, and to help the operator not to make too much effort,
I have already built a manual but the system to lift it makes you do an unnatural movement and so we thought to try to do it pneumatic for safety we wanted to put shutters then I will show you the photos.
if there is an operator reason more to use oil.
remember that it must have safety criteria not indifferent.
the only air system I had seen was for an automatic warehouse, but it was prepondering the speed that only air can provide.
