asse navale
  • Thread starter Thread starter peppe86turbo
peppe86turbo
hello to everyone
Can you email me a design of a board of a boat?
of course what connects the propeller to the motor
:biggrin:
hello to everyone
:biggrin:
you draw a "pocket guy" and here is your axis:biggrin:. That's right, there's also the conical tip for the propeller's calettament.
but what is the request? Doesn't that sound a bit generic? and try to do it you see that it is simply a tree (as mentioned above, a broom handle)? . Always what you need, but you have to be a little more precise.
and then in case, what software do you use? What size would you need? "cad" doesn't mean anything, all drawing programs are cad.
I add that to be the first post, it is not bad. One expects at least that first one is present, as clearly indicated in the rules of the forum and as other unwritten rules teach. Your presentation is less stringed.
then requests cannot be so generic. What do you mean, "a board for a boat"? I could post at tens, but so...
No, we're not.
Say hi.
No, we're not.
Say hi.
I thank you very much for the clarifications you have made and I apologize to all the users for the errors, but I read the regulation a little time ago and I forgot much.. .
First of all your first answer is fine (a simple broom handle).in fact it is what I saw seeing a couple of boats.
Unfortunately I'm an expert on boats, I just started to discover them structurally. I would like to know if there are naval axes with variable section, regardless of the type of vessel. That's why I was looking for a generic design. in fact if there are variable section would be ideal for me.
I would like to make one with ansys to study it with modal analysis to make the project for l3 in mechanical ing.
I hope to have explained I repeat the apologies for having them other inaccuracies or errors (reproaches are always welcome, help!).
ps: I presented myself in the generic section, also it was squeezed because I was wrong with the paste copy....it was for another thing the message.
but you tried to do a simple search with google in the voice line d'asse? Here you have only one example, it's "small girl" but you get an idea:http://www.reggianinautica.com/prodotti_cat01.html- Just keep looking.
Marco:smile:
Let's put things in order.
What ship/boat are we talking about? because you need to know the power to transmit and you know that between a gozzo and a carrier there is some difference.
Then why do you want a beautiful design made? Try to do it yourself.
choose the hull, how long should it be along the axis? if it is a small boat can be a unique piece, if it is a ship, they are more united parts among them.
define at least the power of the engine apparatus, then we see to dimensional it.
Marco:smile:
Well, maybe my big mistake is that I didn't put an axis line in my research... fault of my friend "owner" who when I asked for the first time did not correct me!! Can you recommend a text at this point?
greetings peppe
greetings peppe
Then if you need a catalogue, go here: http://www.nauticexpo.it/and put as a search word "axis", you come out of all sizes, colors and shapes.
but you will hardly find detailed drawings.
is still early to dimensional it... I just want to know how they are,
then calmly we will choose together which must be and the correct way to dimensional it
for now you have already been helping me
greetings:)
