hot room injection
  • Thread starter Thread starter SHIREN
SHIREN
I have to choose an injection with hot room including a control unit
according to the annex
I must have a single injection for each figure
or an injection for every four figures
in the economic count there would be a good difference
It is obvious that if the second hypothesis extends my production cycles
even a 5% is not even mentioned
always be feasible
Thank you very much
hi shiren,
time ago I designed caps for aerosols and it was explained that they would use the first solution you hypothesized.
Hello, shiren.
contact the hot room suppliers (at least 3), who better than them can give you advice?
hi shiren, a question, what is the whole figure?
I thought of a multipoint nozzle.
or maybe one every 4 figures
shiren ciao, if the cap is the classic from bonboletta spray, (without particular aesthetic problems) made in pp or pe-hd, from the point of view of productive cycles and management materozze, surely the injection on every single cavity, has a great return from the productive point of view
for that particular type, regardless of its size, the ideal is always an injection point on the top of the cap therefore for each single cavity as dade73 says. I recommend the suppliers of hot rooms because they already have "nozzles" specific multipoints just for your case.
hi shiren,
Hello, shiren.
Hello everyone
thanks for the answers
is a cap for spray bottles
Then the idea is useless turning around is to save on the hot room.
undoubtedly a single footprint injection
would be the best solution
instead we think of an injection for every four figures with a warm room
with four seals
instead of sixteen classics
and instead of injecting it on the base cap
have the injection on the edge
it is useless to say that the extraction must be with third plate
the interaxes big way we are around 100 mm
the cap diameter is 52mm
It's true that if I call suppliers I recommend myself for the best:rolleyes:
I just wanted your opinion
Thank you very much
Good weekend
Hello everyone
with four seals
Thank you very much
Good weekend
so you just wanted to test us:
the alternative to the nozzles and respective hot room would be to use the sitema to "torpeds" which was widely used many years ago and that now the famous American house calls "cool-one". I believe that in terms of costs the accessories to use for such system cost less but as design you have to engage more.
Bye-bye.
for accessories is assumed a 50% less
some days of prog. more would be rewarded
at the moment is only a hypothesis
Thank you very much
