import a dxf into the table
  • Thread starter Thread starter Giacomanu
Giacomanu
Good morning to all!!! I have a small problem, I should import a dxf into the table of a model, I explain better: I drew a model, I made his table, then I added a sheet (so a new table) and here I imported the dxf that I was interested in, (file-importa-dxf/dwg etc.) but I don't see anything, can you tell me how I can do it??? thanks to all for the collaboration.
control levels.
Make sure that what you're interested in displaying the dxf is on the same layer you've seen in your nx drafting.
Here I am, I think that the import dxf you've run has inserted the curves in modeling, so in 3d.
It's a common thing and depends on how it was exported to its origin.
an escamotage to have your dxf in the drafting of ug consists in making an empty file a view of imported geometry (lines and curves ).
At that point you display the view as cgm and reimport it into the file that interests you.
I hope the problem is efectively this
for the import of .dxf
I follow this line:
obvious in teamcenter with ugnx,
3d model,
with 3d..... new 2d drawing
so I have a "assieme"
2d with "under" as son the 3d,
step in the environment "display sheet",
therefore they are in 3d environment of the 2d,
amount in a free layer my .dxf,
return to the 2d and pitch the view,
with "format _visible in view" visible
for the view of the layer with .dxf
but invisible the other layers.. .
with this method I have no problems
I hope I've been clear.
peace and good
_
thank you all... I also had arrived at the linus solution, it seems quite fast and practical. thanks again and next
I'm new to nx... few months. .
Is there anyone who could teach me how to import a dxf to a table?
There was someone who can give me a video or show me live.
