carcad 3d
  • Thread starter Thread starter Regy
Regy
Good evening to all,
I am a first-time student with 3d autocad (2008 version). version 2d I use it habitually, I am not a phenomenon, but I cable.
I have to design some office furniture objects (scaffals, desks etc...) and for the first time to do this I used this program.
I designed these objects using few functions: I created flat surfaces and extruded them, thus building all volumes. (they are very simple geometric shapes)
How do I now see plant and prospect without seeing hidden lines? if I use the hidden view 3d and try to print both in pdf, and in eps, preview I get a very slim design! :confused:
I hope you can help me solve my doubt (which is certainly a trivial thing) , and I apologize if I started a new discussion, but I haven't found any more on this subject.
Thank you all! :smile:
Bye!
I tried to select my model and activated the flat geometry command, asks me to specify x.y and the rotation angle. . What value do I give to these parameters to achieve a geometry that is not all deformed?
Thank you :)
Bye!
scale x = 1
scale y = 1
rotation = 0
