model fuselage aeromodel
  • Thread starter Thread starter Maverick85
I remade the f16 then also the emb339 (the tricolor arrows to understand us) and I printed the latter being really satisfied with the result obtained, I really believed worse but really I moved to see the mold (for a model is really a great job). .
I ask you only one last thing wanting to amplify all the size of a factor 1.2 is possible (existing a function) to do so without remaking all the work? ?
Thank you very much
I'm glad you did it, but I have to yell at you. . .
I want to see a photo of the mold! (and if possible a finite model)
Unfortunately I cannot answer the question.. .
I apologize.. .
Actually for now I only have the female mold, I tried to take pictures but you see little and nothing, it would be reduced. . .
cmq just ready the model will be posted. . .
ah since you're a model designer who uses resins and where do you take them?
I have to do some economics, at the store they asked me 150 euros more or less for a model, for me it is exaggerated, calculating the rest and the many probable crashes.. .
Unfortunately I have never tried with resin,
I did one on the balsa and then I went to the depron + balsa (not crossed dishes eh! )
I wanted to start with depron too, but I didn't resist the temptation to design it. . .peccato that will most likely be destroyed on the first flight:biggrin::biggrin::biggrin: in fact they recommended me themb339 as the first model that makes more from trainer.. .
Thank you very much
You could make a derivative and the scale factor... .
if you want to change something you have to do on the original not on the climbed one
I mean, in poor words? ?
Sorry about my ignorance... .
do new part -> concludi sketch -> wax the command drifts and go to select your file, in the window that appears you select the scale factor
I don't know.
easier to make than to say... .
Thank you very much.. .
good make
how do I convert my .ipt file to a .dxf file?
I was asked for this format. . .
the model 3d .ipt does not expose it to dxf. (you can export it to igs, stp, sat, etc. )
If it is to cut the templates, they ask you to export to dxf the table 2d of your model.
in fact the dxf in 2d I have already, from that I got my model .ipt, you say they want that in 2d? ?
Now I try.. .
I say you better ask what they want, otherwise who knows what they give you:
:biggrin::biggrin::
I sent him all 3 formats. .
I expect them to answer me. . .
But I don't think that from the original dxf they get the solid...bho we see. . .
:biggrin::biggrin::
Watch that you risk paying them without getting what you want, and then they will also be right.
the dxf does not support neither solid nor surfaces, but only lines, arches etc. even if 3d.
this means that if you have a model and "export a dxf", this will contain all the entities type lines and arches.
Aren't there? Well, the dxf will be empty. Pay attention to the size of the file, if it is below the mega may contain only the headers and layers!
then I asked if they created cad project molds, they asked me the dxf format to see if it was feasible...I sent him the original dxf (2d containing sections etc.) the solid that I got in .ipt and the conversion into dwf...
my question is still valid, is there any way to convert my .ipt file to dxf? ?
My answer is still valid. It's like asking if I can convert a dwg to mp3
dxf does not contain solid entities. you have solid entities? (I guess so). then no, or at least not directly.
if you do the various sections, those you can export to dxf. but of course the information content will not be the same.
