Why English?when creating a new projected view, now you have the possibility to connect the configuration shown in the new view, referring to the parent view.
it is also possible to set it as default.
excuse me let me understand well, until 2010 I change the configuration to which the view father is referred and the projected view remains associated with the original configuration, if I do not manually intervene to put things back in place?? ? ?when creating a new projected view, now you have the possibility to connect the configuration shown in the new view, referring to the parent view.
There are interface and translation problems, so that I text both languages and if I find problems I report them to the dealer.Why English?
Marco:smile:
..quelli a bizzeffe :biggrin:There are interface and translation problems,
Unfortunately it is so.excuse me let me understand well, until 2010 I change the configuration to which the view father is referred and the projected view remains associated with the original configuration, if I do not manually intervene to put things back in place?? ? ?
Look...the problem is equal to everyone's house...quelli a bizzeffe :biggrin:
Marco:smile:
Thanks for warning me, this could be a very serious problem source if two seemingly tied views refer to different models.Unfortunately it is so.
every view can be independent and if you change the configuration in the parent view, until 2010, you have to change it by hand even in the projected views.
I talk about model configurations, not different models.Thanks for warning me, this could be a very serious problem source if two seemingly tied views refer to different models.
I got tired of this story and I didn't score anything. I know it's not constructive, but in recent years I've lost a lot of hours (that nobody pays me) and then feel that there are probably few reports and you don't know when they will settle. If for me it is blocking mr swx should take someone who works there immediately or almost and solve the problem, also because I realize that everything I know works.Look...the problem is equal to everyone's house.
you must see the translations in Italian of the other cad.
Moreover the passage from xp to view was a slaughter.
the font has changed and many buttons no longer contain the whole text.
the only solution is to report them, even if the var refuses, send it to solidworks italia and tell him that the var refuses to receive such reports.
You're right, but the problem is only with Italian vars.I got tired of this story and I didn't score anything. I know it's not constructive, but in recent years I've lost a lot of hours (that nobody pays me) and then feel that there are probably few reports and you don't know when they will settle. If for me it is blocking mr swx should take someone who works there immediately or almost and solve the problem, also because I realize that everything I know works.
at the end the speeches with theassistezna are always those, the software is complex, there are many users, many ways to use it, etc....... I care that if I deliver a wrong design they make me a bunch so much, and besides being careful to me I have to watch the software too.... .
