work plans
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone,
You've already talked about work plans bound to sketches in another discussion, but the "search" doesn't find it, who remembers what it was?
Anyway, that's the question.
environment together; sketch together; I should build a plan between a sketch line and an axis of the set, perpendicular to the sketch line.
I thought you could do it, but I can't.... .
you must first create an axis matching with the sketch line....
Yes, I remembered that, but it doesn't take it, that is, the commands slowly, axis and point not "sent" the sketch, if I step on with the muose during one of these commands, it is as if there were no... ,
I add that he does not hear the sketches created together, if instead I make visible a sketch made in one part, then, in the assieme, that sketch becomes valid for the commands of plan, axis etc.
I'll confirm it happens to me, too.
I just started using rel 2011 systematically and I have the same problem.
the beauty is that it does not happen on all assemblies and I did not understand what is discriminating.
I'll fix it, but there's something wrong.
In fact, thinking about it, sometimes it does so to me...
question: are there adaptive parts?
Yeah, they don't want to know how to adapt. .
I try to take them off, and maybe turn it off, you never know.
It's a problem I have, too. :frown:
But every now and then I have to make them adapt... :redface:
nothing to do, even removing the adaptive parts, does not want to know about sketches to make plans.
bho, I'll do otherwise...
Thanks anyway.
You could do a new part where you hid in the voice of the separate components. then use it to put the sketches you want to use to create work plans.
In this way, it doesn't appear separate and you can turn it on and turn it off.
I initially did so, but it seems a little bit of a remedy, so I did differently the construction and solved with flexibility of some parts together. . .
