pallinating explosion in a new design
  • Thread starter Thread starter artiglionero
artiglionero
hello to everyone, when I cover a ball from a drawing in a new and/or in another design the ball explodes.
I ask you:
- Is it just mine?
- Autodesk just thought about it?
- is there a command or variant to enable or disable this?
Thank you very much in advance
I ask you:
- Is it just mine?
It's normal. the ball, as you call it, is connected to the ball that is part of a db present in the drawing. moving it into a new design the ball is reorganized in the db of the drawing and takes another position number, so you have to recreate the ball.. .
What do you mean, connected to the ball? ? ?
means that the ball is not a trivial graphic object, but an intelligent "rimando" to a record of the mechanical database, in short, a kind of link that will feed the final b.o.m. (correspond to me if I wrote badly, inventor...)
what I call pallino and the symbol of the circle with x above of cyan color. . .
the ball is the position number with the director. . .
