rich problem quote
  • Thread starter Thread starter thedoctor207
thedoctor207
Hello everyone,
I have a problem about a set to compose on solidworks of a bozzello with hook. I have been assigned all the quotas of the hook, while I have absolutely no share of the draft and I know that the scale of the same must be derived from the design of assemblies.
I am not sure but there should be some solidworks command to make that through the hook quotas, I can get the bozzello shares.
Can you help me?
thanks in advance
Hello everyone,
Can you help me?
thanks in advance
Excuse me but I understood little (or nothing?:biggrin:).
you have the design of an overall, quoted but not completely; here, but is this design already a solidworks file or a paper print or pdf document (or an image)?
because if you have the 3d model the problem does not arise, the piece "exists" and has dimensions. If you have an image or a paper instead you will have to shape it and size the checks you while you do it.
in this case you must obtain the scale "on the card" proportionally to the few quotas that are indicated; with ruler and calculator to make a simple division.
explain yourself better and post images and/or files of what you have.
better explained and post images and/or files of what you have.
Hello
marco
Miiii... but is it possible that you are so gnucious?? ? :biggrin:
Hello Marco
Look, I have a paper design.
So you give me the bad news that I have to measure every single dimension with the ruler? There is no direct way through solidworks (I had heard of something like modular quotation. . . )
thanks for the help
Give me some imagination. create a surface, stick the image, scan, design and create a sketch "calculating" the geometry you need!
finished the sketch the steps to the desired size, 5 minutes and passes the fear.
never used a veline card?? ?
mike 1967 seen that you know everything kindly you can not answer.. .I don't stand here to lose time, it's a drawing for an exam so kindly don't answer anymore
Okay, sorry, but the answer is consistent with your request, but I still take note of it.
Happy birthday to the exam.
ps: maybe you did "the stick"... I meant to put a texture on a surface from
use to recalculate, through sketch, the geometry you needed, I repeat my best wishes.
ciao marco
guarda I have paper design.
thanks for the help
Yes, of course!...... .
do so:
open a new side file and enter sketch mode.
put your paper on a ledge and place everything in front of the monitor, at a distance of about 20 cm (which are well centered and parallel). light an ultraviolet light (or ultraviolence??) and direct it to the sheet (so from behind the monitor). regulates the ambient temperature at 0 °k (-273.15 °c), exit from the room (you would resist little...) and from this moment let spend at least 2 hours (depending on the complexity of the axieme. maybe do some tests with small details). After that you raise the thermostat and return, you will find your set with all the details and tables quoted "magicly" saved in fine order in the hard disk. distinctly understood, and if everything went to good end even with the quotes of the suppliers (to have the "print 3d" from rapid prototyping are working us for 2012).
I forgot.
all the operation must be carried out on the midnight of a night of plenilunium.. but it must not rain.
and remove the screen saver and all stanby modes (which obviously will not work).
:biggrin::biggrin:
Come on!
try to reread (and above all rethink) the things you said and that you claim.
I'm sorry, but who should make the drawing on the computer? and of course drawing you have to assign dimensions.. No?
after which solidworks gets you anything, but first a file/model you have to give it "to eat".
Marco:smile:
sampom but it was no easier to write to me: Is there anything you ask?
I'm just saying that you've lost so much time writing all that stuff... there's to say that the "fantasy" as our friend mike 1967 told you is not missing. .
cmq I apologize if in this forum formed by "excellent" users, I lowered the "cultural" level with unnecessary questions...I thank you and I wish everyone and especially to mike 1967 a good continuation. In my life, I mean and...
I don't understand you, more than give you an indication of how to do... Mah...
in a few months, when you learn solidworks well, rereading my
You're gonna say, what a pier, that's what he meant.
I'd like to explain how to do it, but you banned it.
In the meantime, happy birthdays. :smile:
irony and fantasy aside (that in life, Remember, always help.. and here there is no "excellent" or "cult", or perhaps all but it doesn't matter), I just hope that you understand the juice of the speech and that what you ask would be science fiction (so even to ask).
you have a drawing on paper and you would like a software, without doing anything, to model it "inventing" of the quotas that, until it is inside the pc in the form of files, do not exist.
you have to bring the design back to the cad program!
if we are talking about standard/commercial/unified elements for which your hook corresponds already defined drafts (but this we do not know, you must say. and how you explain it is difficult to interpret) then you could find on the net and/or the producers of the ready 3d models. I'm pointing out the hook with the known measurements and the corresponding stamp.
you can create a "freedom of models" with all those unified elements. only from that moment the program will be able to help you in choosing and sizing, but first it needs data to be inserted and this only you can do it.
otherwise learn to understand what you read (besides what you write) and follow the correct advice of mike, who had seriously explained a possible solution. . sure to "add" in course of work but still a good way to start the work.
If I had a paper design, I would scan it and how image I put it in the sketch through this command.
the problem of proportions is solved by pulling a line and quotating it with a value present on the image and then the same resizes until a entity listed in the image does not match the sketch line.
Then you resign us over.
within solidworks there is also a function of tracking images, but it only works with certain images and that they are sharp.
I attach the path for your reading.
right,
and that's what mike suggested briefly.
Marco:smile:
right,
Marco:smile:
ahh less bad that someone understood it, I thought I was "cripical" (no so
but he was pissed by saying: .
Look, Marco, I'm doing marilin gigantography. in sheet :biggrin:
Hahh... I forgot... My wife entering the house, she found me in the middle.
to the marilin thighs.... He exclaimed: but micheleeee...:biggrin:
@thedoctor207, if you are underage, don't look at my previous post, maybe
you're hurting us...:biggrin:
cmq I don't say anything else except that you could give me these suggestions using a less sarcastic tone and teasing...especially you mike, ke you can also know solidworks like your pockets, but this doesn't allow you to tease who you are starting to know now this program. even you at first could have difficulties (or are you almighty gods that you already know everything?) and you will have also asked stupid questions: surely if you were addressing serious people did not answer you, "what questions from pyrla you do.... "
the fact is that on site forums you all seem a little mounted therefore even if you can give good advice, you put yourself wrong and so do not serve much... .
(for the record, mike, I'm not a minor, I'm just much younger than you, even if by the speeches you do and the phrases you write, you would say all the opposite about our age............ )
You don't deserve an answer, I could be really sarcastic and, especially rude.
Thank you for thanking us. ...
Hey, remember to grow up.
ps: I hope I didn't help you get ideas from my suggestion,
Remember that you banned me from writing again... So... you can't benefit from it.
I'm... You have to pay pledge. I'm sorry.
I've had a chance to talk about something.
I...
almost 700 posts and no questions.. .
you 5 posts 4 of which insults.
See you...
I'll put the red carpet on you.
I'm sorry for the brevity, but I'm walking around with the dog. must do
kk.
with the utmost kindness I invite you to reread (and try to understand this time) the first response post of mike:
I guarantee that the suggested solution is correct and serious.
I don't see sarcasm or ilarity or "hope around".
only a "light", friendly; normal between the users of this forum, of which you obviously did not grasp the spirit.
read a little discussion, especially those to which mike participates (in the specific case.. Since you've "started" it and I can't understand why), you'll see that it will be easier to get closer to "this world." but do it with good eyes and brain.
then learn to smile (especially to smileti) that of kk in life you will have so much to eat.
Marco:smile:
