inserire files in cc
  • Thread starter Thread starter Brethil
Brethil
hello to all;
Excuse me, would someone explain to me how to insert in my default cc (I am single user and I do not use the vault) of the parts I created, so that it can use them as I already do with screws washers and bolts?
I don't know if I have to create a separate library or if I can somehow open the cc editor and stick the above files...:confused:
thanks in advance.
_
the operation to do so is the "publishing", the command finds it in the management board.
you must, however, have first verified to have a free library in writing (my library) uploaded in your project. to open the project window configure libraries and, if that's the case, put the visa to my library. Now you can use the cc editor to create folders and subfolders and then post the parts.
Thank you, thank you.
finally with your straights I managed to create standard files in the cursed cc!!! :finger:
you are really a thicket
...if you want to cancel them now to get them back to another family? (you know, I'm doing some evidence). .
:confused:
in any case thanks a thousand more:smile:
:confused:
at the end I made it only to erase them; Thank you for your valuable advice.
:biggrin:
