installation and start problems inventor 9
  • Thread starter Thread starter Simone Panico
Simone Panico
good day to all; I tried to install inventor suite 2009 on windows 7 home; at the first attempt the installation stopped (or better it continued for about 5 hours until I blocked it) when I was installing aws; I tried again after uninstalling everything but the results were the same. Finally I installed only inventor 9 (without aws and libraries). it ended positively. I opened the program, started a first drawing, closed it together with inventor, then when I tried to open it again, inventor crashes and appears the following writing: "autodesk inventor 2009 stopped working
windows: a problem has occurred that prevents the correct operation of the program. if a solution is available, the program will be closed and sent an automatic notification. "
I tried then to uninstall and reinstall several times but did not solve the problem. The same message also appears to me when I try to open inventor directly.
Do you have a solution for me?
Did you check that inv 2009 is compatible with windows 7 home? no because inv 2009 came out in mid 2008 and I don't think that win7 was already on the market at that time.. .
try to completely disable the "user access control" and antivirus (if you have it) and try again. If so, make a non administrator account and work with that in everyday life, and reserve the admin only for maintenance tasks on your machine (disable the uac and go on the internet as admin means freeing various virus and trojan prairies).
I'll explain. pre-view and pre-seven programs do not know about this uac, so if windows forbid him to do one thing (typically write in the registry or in the program folder), they do not go to ask uac to be temporarily enabled, but they simply plant oppues remain waiting for divine authorization indefinitely. This ban does not exist in versions of windows up to xp, if you are administrator.
Simone Panico; said:
good day to all; I tried to install inventor suite 2009 on windows 7 home; at the first attempt installation .................................................................................................................................... problem. The same message also appears to me when I try to open inventor directly.
Since what good disposition you find in this forum section????? :biggrin::biggrin:
So, since he's entering this "house," it wouldn't be bad beyond having to say, "Mad: go into the presentation section and tell us, who you are, what you do, what release you use, (even if you wrote it in the post, it wouldn't be bad if you indicated it in your profile).
What do you say?
