quotatura verde militare
  • Thread starter Thread starter ander89
ander89
I had files (part and design) derived directly from a library.
I remade the part (using the same library) and reused the same design so that I have all the odds made. in opening the drawing a message is displayed "the document reported has an internal id not corresponding". I selected the second option i.e. "use this file anyway" and found the design exactly as it was before the change of the part. the only problem is that now the quotas are no longer gray as usual, but they have become military green (perhaps this is due to the fact that the design still refers to the part that is now no longer there).
do you know how to return gray quotas?
p.s.: I attached the message and an example of the result of the quotas.
alternatively, is there a way to quote the new part automatically using the same shares of the old part design?
you tried to see the references of the drawing (i.e. to which part it refers) when you are in the "open" window ? then the problem can also be that the odds were placed directly in the table and replacing the reference part the odds themselves lose the points of reference (discuss the word game).
One way to avoid these things could be to import quotas directly from the side, with all other annotations (salvations surface finishes etc.) ; so avoid the quotation and above all the inconsistencies between part and table file, sometimes the procedure can be laborious as you will have to hide those quotas that do not interest you, but in my opinion it is the best method of making the table.
to import quotas, see the help, you can do it directly when creating the view or later with the appropriate command under the annotation menu.
I hope I've helped you, hello and good work
I remade the part (using the same library) and reused the same design so that I have all the odds made. in opening the drawing a message is displayed "the document reported has an internal id not corresponding". I selected the second option i.e. "use this file anyway" and found the design exactly as it was before the change of the part. the only problem is that now the quotas are no longer gray as usual, but they have become military green (perhaps this is due to the fact that the design still refers to the part that is now no longer there).do you know how to return gray quotas?Thank you.
you can reuse green quotas by attaching them to geometry.
You do almost before you get back to the old ones. calculates that for the majority of odds you have to click at least 4 times (4 points) to fix a release while making it a click on the entity. to reposition it, if you put it exactly on the previous one, then, 90 out of 100, selecting the quota you select that undelete and you can delete it.
not to count that if you are unscrew both sides and risers line and line do not hook up. you have to select line-vertice and often you have to resort to filters to succeed.
but it is quite useless to do the 3d at this point.. If I add the quotas in the table and then change the part the quotas do not change alone to make the 3d does not exactly serve at nothing.. If I change one small part then they go into crisis all the odds and being to erase them and give them back is like doing things twice.. ridiculous!
No. if only "modify" the part by changing the sketch or function quotas added at the table are correctly updated.
if you change the reference body the quota at the table gives that "defect". It also seems right, because it no longer finds the body to which it was initially assigned.
If you want to have the table completely parametric you have to import the quotas of the model.. here it is a habit to share sketches in a certain way so that they can be easily used in the table.
eye in this case to those who and how will handle the table, because those odds are like those of the model; If you accidentally edit a part 3d.
but I changed the share of a sketch. I modified a sketch that then gave a sort of chord in rotation but then just become green all. I understand that only the share of the arrangement that I have changed, that I put a moment to remake it, me who become all green becomes quite heavy. because I have a lot of them and I have to give them back.
