count and number the blocks belonging to a layer
  • Thread starter Thread starter gennarochiocca
gennarochiocca
I need advice,
I would like to split a macro vba that accounts the blocks in a certain layer and then numbers them automatically, it could be useful to me the bcount command.
How can I do that?
thank you all.. .
and good to make.
I need advice,
How can I do that?
thank you all.. .
and good to make.
What do you mean by numbering?
then to select blocks belonging to a layer an example is this:
dim element as acadblockreference
dim sset as acadselectionset
on error resume next
if not isnull(thisdrawing.selectionsets.item("element") then
set sset = thisdrawing.selectionsets.item("element")
sset.delete
end if
set sset = thisdrawing.selectionsets.add("element")
dim filtertype(1) as integer
dim filterdata(1) as variant
filtertype(0) = 0'(dxf filter entity code)
filterdata(0) = "insert"(block filter)
filtertype(1) = 8'(dxf filter layer code)
filterdata(1) = "name_layer"(code dxf filter name layer)
, filtertype, filterdata
sset.count (from the number of attachments covered in the filter selection)
'then there will be a cycle to make numbering (I have not understood what you mean) but it will start with:
for each element in sset
next element
with the information you gave the most I can't help you.
