Musical76
I kindly ask you a tip to draw a spring.
work with nx4
until the helical command I have no problem, but wanting to define the spring in a more precise way, that is with the last closed, or crushed edges, as you prefer to define them, I encounter some difficulties.
I tried to use the law function
but I have difficulty defining the long variable z,
if you can.
do you have any suggestions about this? on the best road to follow? ?
work with nx4
if you can.
