jim78b
in the autocad layout because if I want to make notes like quotation, make arrows, tests etc on the viewport puts everything under it? even if I carry on nothing to do!
open the print window you have to select in the "print options" the so cute voice "print paper space after" and you will see that you will print everything on. the door command above does not work in that case...in the autocad layout because if I want to make notes like quotation, make arrows, tests etc on the viewport puts everything under it? even if I carry on nothing to do!
