lory.b
You can always try this gabola.but by doing so I will no longer have an up-to-date viewport whenever I make changes to model 3d, right?
wax a thin wall of the thickness of the plaster and put it in front of the two walls of different thickness. in this way the artistic rendering will see a single surface. put it on a special category to activate only in the viewport.
I understand that it is not the optimal solution, but the artistic rendering, as the name itself says, is born to give a "hand" effect of the design, therefore creates a grosser rendering, not of precision.
I do.
