juanpablo87
Hello everyone,
are "almost" new on this forum
I wanted to ask you a problem I couldn't find a solution. . .
in practice, given two columns (then fixed interasses...) I have to build on a bow starting from a box...; I then apply the blend with an angle of 180° and rotated by 90° compared to the axis z...and so far everything easy....; but in order to allow the other end to reach the other column I have to move the center of the blend modifier...; and here everything is smooth: the problem is, however...how can I perfectly match the upper base of the incurved box with the column!? I put an image.. .
thanks in advance...
