create sketches on the table and quota that you do not relate
  • Thread starter Thread starter oloap72
oloap72
hi, for about 6 months the company where I work has finally passed from the 2001 version of pro-e to that wildfire 4. we found a problem with the setting up of the table, with 2001 if we created a sketch directly on the table then we related it to the view and, then we inserted a quota, when the view was moved inside the format itself, the share remained tied to the whole view.
Now instead, even if we associate the quota to the view this does not move jointly but remains in the starting position, basically there is no connection... how could I solve?
thanks in advance
select the sketch created, click menu edit/raggruppa/associa to view.
thanks for the answer, what you told me is practically what we do already, that is: change > group > associates with view, but despite this, the link does not happen... Maybe we should set up something in pro-e options? It seems a banality but this problem creates a little inconvenience with the tables.
Thanks again
Thanks again
if you do so and the bond does not happen, or rather it happens only for the association of entity 2d but not of quotas, it means that you have not set a fundamental option in the design configuration file, that is:
associative_dimensioning must have yes
Thank you for saving us! !
I am happy you have solved.
sure that you have made a nice leap from 2001 to wf4, that option is by default on yes, I do not remember if in 2001 it was by default on no or maybe in the upgrade someone put you hand to the design configuration file creating the hippo, this is typical... :-)
